rear brake help
i built a 250af with a 250f frame and a 04 250 motor. im having a problem with my rear brake, u have to push it really far to get it to stop, it is adjusted just above the peg height and i have good rear pads, what else can i do, all the brake parts are from a 07 kxf 250
Bleed it. If that doesn't work then the seals in the master cylinder could be bad.
Check your line for any lumps too.
