Big bore advice
Hi, im finally putting the drz back together after about 6months of it sitting in pieces (broke gearbox, then broke my ankle)
I figure whilst its all apart, i may as well chuck a big bore kit on there as well.
Now, im assuming its would be pretty useless without changing the carb (its a SM, so fcr).
Also, what cams should i use? are the E cams equivalent to the hotcams? i think i saw that somewhere, but cant remember, its been so long.
Finally, should i change over valves at the same time? They are stock with 30k kms on them, but have stayed in spec since new... so im unsure if i should change them at all, or what with if they need it.
(i searched, but couldnt really find what i was looking for)
Thanks, Tom
HotCams stage1 are comparable to "E" cams, either one will do the job. Myself, i would put in new valves since you are in there anyway. RHC valves would be the first choice. Stock valves are crap 2 piece design.
Mike :thumbsup::confused:
