Is this FCR compatible?
I know, I know, another "will this FCR fit" thread, but I haven't been in the market for an FCR until recently and for all the FCR's that I have looked at, I still realize that I know less than next to nothing about them....so can anyone tell me if this FCR is compatible, or if not what it would need to bolt up?
Thanks in advance, I appreciate it! :thumbsup:
I see a removable intake bell, that's good. I see an air cut off valve. And I see a wire for TPS. External AP linkage. Need a good left side and right side shot without shadows to tell anything more.
Used carbs can be problematic from wear. What is the plastic case? Jet kit for what?
Noble and Eddie, thanks. Those are the only pics that I've got. The jet kit says its a JD kit for a DRZ400E/K non-Cali, KLX400, Keihin 39mm FCR.
I know used carbs can be a hassle, maybe enough that I would rather just cough up for a TT FCRMX kit.....but the price might be right on this one to maybe take a leap.
So it could work from a WR? With the right intake bell it could do it?
I had a fcr39 like this from a WR , you also need 'E cables and of course 'E intake manifold and Sudco adapter .
These carbs where used first time at 1998 on WR and at 2000 they upgrade to fcrMX , now it's 2011...
Thanks for the info! :thumbsup:
And.....yeah, thanks for the food for thought, too..........
If I remember right, those early WR400 carbs had problems with breaking the plate that rides in front of the roller slide. Also check for body wear where the slide rollers track in the body.
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
