Carnegie question.
California
Heading up to Carnegie at the end of the month. I have an aftermarket pipe and I do have a spark arrestor but the sticker that came with it is long gone.You could actually see the screen when it's installed. Will they let me in with the spark arrestor but no sticker for it?:thumbsup:
If they can see the screen they most likely will. It all depends on what side of the bed they wake up on.
If it isn't marked they look and/or stick rod in the end of the exhaust to check for a spark arrestor. So it shouldn't be a problem.
http://www.fs.fed.us/recreation/programs/ohv/OHV_SAG2007.pdf
OFF-HIGHWAY VEHICLE SPARK ARRESTER
INSPECTION PROCEDURES
Forest Service Standard 5100-1c requires that each arrester
shall be permanently marked with the model number and
the manufacturer’s name or trademark. The model number
must match exactly. The identification must be stamped
in the metal body or on an attached metal plate. The words
“Qualified” or “Approved” are not required, and do not
indicate that the unit is in fact a qualified arrester.
1. If identification of the manufacturer’s name and
model number is found, then refer to the “Qualified
and Rated” list.
2. Check the “Qualified and Rated” list to establish if the
arrester is qualified.
3. If not on the “Qualified and Rated” list, be sure to
check any SAG update information you have received
since the time of the printing of your present SAG.
The absence of an arrester from these lists indicates
that the arrester has not been qualified.
4. After the arrester has been identified, turn to the
Drawing Section and check the spark arrester
5. Suggested tools for inspections:
a. Hand tools to open cleanout, screwdriver, and
pliers.
b. Flashlight.
c. 1/8-inch wire rod or stick to probe inside the
arrester to determine if stationary fan or vanes are
in place.
d. Tape measure.
e. 0.024-inch wire gauge to determine screen size.
6. Inspect to ensure that:
a. The spark arrester is correct for the position of
application.
b. The exhaust system between the engine and the
spark arrester is in good order.
c. The arrester is properly maintained and cleaned out
when necessary.
7. More detailed instructions are available in the
NWCG video, “Spark Arresters and the Prevention of
Wildland Fires.”
8. Follow your agency’s policies when an unqualified
spark arrester system is encountered.
Carnegie SVRA
Telephone
Ranger Station:
(925) 447-9027
District Office:
(925) 447-0426
Emergency:
This is what the Forest Service has to say but read the bottom line, call the places you are going to ride on...TJ
it shouldnt be a problem..
not sure what kind of bike you got, but red sticker season is over. so i hope you have a green sticker bike.
Like Infamy said, should be no prob.....And yes, it is greenie sticky season only right now at Carno..
Thanks for the replies. I know that it's green sticker only right now that part is not my worry, CRF450X. Just wanted to see if they were super strict on the regs. The only place that I have been checked is at McCain Valley down here in San Diego county.
Edited by BrassOnes
They will also look for a smog\air pump. No pump = no entry.
And it will probable be dry and dusty....I cant believe I didn't get one good ride in this year at Carnegie, it was either a day early and the mud just clogged up my swing arm or it was dry and dusty. If you can hit it right the traction is awesome there.
(note be careful and don't do this when hot, don't want to poke a hole in it)
If you can see the screen at least keep this in mind, generally if they can see a screen and it can pass this test they let it fly, no grantees however Law Enforcement people from different agency's often play by different rules...TJ
That would have been between 9am and noon on the last Saturday after the rain stopped. Then it became a dust bowl.
That is such an embarrasing law/policy.
Oh well, just cram a marble or a ball bearing in the tubes. All the dumb thing does is make the bike pop.
Since the day I brought my CRFX home I have been told to do a block off or do the JB Weld mod, I actually have had a block off kit in the tool box for the past two years. If I had used the kit it would be just another thing I have to do for this trip. The pop just doesn't bother me.:thumbsup:
My trip to Carnegie has gone into the books as a successful one. Not sure what I was worried about ranger at the gate didn't even look at the bikes in the back of the truck. The weather was great and there wasn't a crowd. I dropped the bike once, thank goodness for hand guards. Nice little riding spot.:smirk:
Last time I was there, four months ago, we pulled up to the booth and the kid
working the booth said $5.00 please, we paid and drove on through.
Yeah its the same at P.C.,Mamoth bar and Hollister too. Sometimes you get the third degree and the next its hand over your cash and go.
I ride Carnegie lots in the winter and have found if you buy a season pass and just wave it they just wave back and don't even approach your truck...I hafta admit I wonder if it would work in red sticker season...:smirk:
x2 , you get bothered less with the annual pass. ive got my monies worth on this years pass already and i bought it in april :smirk:
