lights on ttr230
I was planning to buy a 35watt headlight from walmart and mount it to my dirt bike. Does anyone know what wires i need to tap into to get it working.
I believe the wires on the lights are just one black and one white.
I can't say specifically for the 230, however, what I did was run a relay directly from the battery, the relay coil (the one that activates the relay) came off a wire that when the key was switched on would go hot. This way the light isn't taxing your wiring harness.
Be sure to fuse the wiring too, no lights is better than stranded or worse on fire.
