Removing shift drum bearing?
Does anyone know the correct way to remove the little bearing the shift drum sits in? Its an 03 cr250 btw. There is a little opening on each side but Im not sure. Anyone?
blind bearing puller.
or you can do it the, red-neck,hill billy my mother is my sisters doughters dads cousin way and use a carbid bur and a dremill and cut the bearing in half cairfully.
Hey that'll work. But whats a carbid bur? I've got the dremel.
case bearings like be frozen and dropped into a nice oven-warmed case. should not need to "force" bearings into the case ever.
a carbid bur is basicly a cutting tool...google it, to hard to explain.
as for puting it in. freeze the bearing and warm up the case ither in the oven or with a pro/map gas tourch.
