Kx60 fork conversion
I WAS RECENTLY LOOKIN AT THE KLX110L'S AT THE DEALER AND NOTICED THAT NOT ONLY IS THE BIKE ABOUT A INCH TALLER IT HAS STIFFER SUSPENSION. (I CAN BOUNCE MY 170LB BODY ON THE SEAT FROM ABOUT 6IN UP AND IT ONLY SAGS ABOUT 1/2 IN, IF THAT MUCH.) SO I SAID HMMM, I WONDER HOW LONG THIS SHOCK IS :thumbsup: .. MEASURED THE SHOCK AND IT'S 1 INCH LONGER, EYE TO EYE. WHAT IM WONDERINIG NOW IS HOW I CAN COST EFFECTIVLY GET THE FRT UP 1 INCH TO KEEP HER LEVEL. IS THE KX60 OR KX 65 FORK ASSY LONGER THAN THE STK KLX110 TUBES? IF SO I CAN LIFT THE FRONT AND UPGRADE THE FRONT REASONABLY CHEAPLY. (YOU CAN ORDER THE STK "L" REAR SHOCK ASSY FOR A 2011 FOR LIKE 170 ON WWW.RONAYERS.COM) ANYBODY KNOWS, LET ME KNOW PLEASE!!:confused:
YES, THE KX60 FORKS ARE LONGER THAN THE STOCK KLX FORKS. THEY ALSO FIT RIGHT INTO THE KLX TRIPLE CLAMPS AND CAN USE THE KLX FRONT WHEEL.
YOU'LL NEED AN XTENDED BRAKE CABLE & POSSIBLY EXTENDED TROTTLE CABLE (BOTH AVAILABLE AT FASTERMINIS.COM). GOOD & CHEAP FORK UPGRADE.
sorry for shouting... i couldn't resist.. haha..
