Antigravity Batteries Product Giveaways - ENTER NOW! Read more... ×
How much power out of Exhaust, Jets, and 3x3??
Just did my 3x3 yesterday, going to pick up my Full Leo Vince today and installing it and JD jet kit tonight.
How much power can I expect out of these mods? 3-4 HP??
Im so excited, Also just got new tires, race break pads, and steel braided brake lines. Going to my buddies mountain house up in Lake Lure for the weekend to ride:banana::thumbsup::banana:
It will wake her up a bit! you will be happy!
good I hope so. Hopefully installing the Jet Kit will go smoothly....
BTW is there a trick to getting the carb out?? I literally yanked on mine for about 10 minutes before I got it out.
did you drop the sub-frame back, remove the top bolt?take the tank off?
yea I loosed up the frame to give it some wiggle room and I took the tank off.
just take your time. I remember it was a tight fit! I had to do it like twice before I got the jetting right!
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
