Fuel Screw (aftermarket)
Which fuel screw is best to replace the stock one on 2004 CRF250x? Brass vs aluminum? T screw vs otherwise? Brand names and experience are greatly appreciated.
I use the Flex-a-jet needle. It's the only one that you can use sitting on your bike, it's easy and works great. The only down side I have heard of but never experienced and I've had 2 is that they can can become stuck. If you're concerned about it, I would either use a touch of anti-seize or give it a twist back and forth every few months.
i dont remember what one i have but im gonna get the flex a jet one soon,i still cant adjust mine that easy though its easier than stock,i havent needed to adjust it after i jetted it but all the same i would like to do it easy if a had to lol
I run the Brass T-handle from Kouba. I read here somewhere to stay away from the Aluminum ones as they are softer than Brass and can deform if you bottom them out.
brass for me too. the flex one would be nice, but i get by with my t-handle just fine.
I have one by Pro Circuit and don't like it. It is one of the aluminum ones and is very hard to adjust. It has a knurled surface but I still have a tough time getting it to spin. I usually use pliers and have managed to wear off the number marks that are on the knurled surface.
yep, the ones with a round knob take 2 fingers to turn. T handle you can just push or pull with one finger easily. My only problem with the flex is the can sometimes get fouled and not turn , like the idle speed cable does, but then maybe you don't ride in the same junk I do....?
The 250x i just got has a similar one fitted and it was almost impossible to turn with 2 x fingertips, i ended up slackening the boot bands and twisted the bottom of the carb out a little, making an adjustment then re-aligning and tightening between each adjustment:bonk: Sort of defeats the whole object of fitting it really:banghead:
The flex jet sounds the best way of doing adjustments when out on the trail:thumbsup:
+3 (or is it 4) for the T handle. I've got an STX with a square head on my bike and put the T handle on my son's. His is a snap to turn...I need 2 fingers on mine, but at least I can turn it and the square head makes it easy to know how much I've turned it. So the square is better than round...but T is better yet.
Can you adjust the T handle screw when the bike is running? If not then the T Handle design is inferior to the Flex jet.
Yes....and you can adjust the square headed one too while its running. T handle is much easier though because don't need to get a finger behind it. Just stick a finger in there and either pull on one side or push the other....or use two fingers. Couldn't be easier unless could do it from seat of bike.
Now...for those of you in the gutter....thats NOT what I was talking about :smirk:!!
Dave
  • Similar Content
    • By Hayden Ploeger
      So I have never actually posted on one if these forums. I usually just stalk them to get answers but I messed up and I might be out 800 bucks🙃
      I have a 2013 CRF250L that I recently bought and I wanted to get supermoto wheels for it. I got online and almost ordered a set of warp 9 wheels but then I saw an add on Craigslist. Long story short I purchased lightly used warp9 wheels from a 2012 CRF250X not realizing the axles are different sizes. The rims are the same size as what comes in the kit from warp 9 but the spacers and bearings are larger on the wheels that I got. Does anyone know if I can buy new bearing and spacer kits to go in these hubs to fit them on my bike or will I need to purchase new hubs entirely?
      I work on a fishing boat and I'm off the coast of Oregon for a few weeks and wanted to order something so I can get these wheels on my bike when I get home.
      Thanks,
      The guy who f***** up
    • By yrun
      I have a new 16 crf250x.  Would like gear it up a bit for two track, orv trails.  How much can i drop the rear sprocket size without shortening the chain.
      Thanks men!
      Joe
    • By yrun
      I was working on installing new needle for JD jet kit today. While trying to get a bit more rotation on the carb i broke a little plastic tee on the top of carb (left side). I think its some sort of vent? Not sure if the brass part is threaded into carb or not? At any rate it will have to be replaced. Wonder where i'd get this little item?
      Any ideas?
      Thanks joe
    • By ronbuell
      Ever been bored or really ticked off by not being able to reach your fuel screw for trailside adjustments?  Well, I decided to do something about it, and not spend a bunch of money to boot!
      Parts liste included:
      Short length of brass tube. Short piece of old, broken speedometer inner cable. Nut from the rejects bin.   I welded the nut to the speedometer cable inner and soldered the other end to the fuel screw using the brass tube as a connector.  I didn't need or fab up a holder for the end, but I wouldn't be too hard. My DIY flexible fuel mixture screw works great and the price is right! I highly recommend this mod.
      Cheap, but effective DIY fuel mixture screw
    • By Frana
      Hi everyone. I’m new here so I don’t really know what to do but let me explain what’s up, so I bought this 2008 CRF250X today and everything looked in tip top shape, but within a few minutes of riding the engine and radiator gets to hot to touch and then the bike dies at low RPM, then it is a hassle to get it started(i drained the battery trying) and once it fires it dies super easily again like by touching the trottle or just idling and I have to be super cautious on the throttle to grt it going. I don’t know if it is overheating or if there is another problem, if anyone could help me it would be very much appreciated.
