Polisport Halo
Just Bought a Polisport Halo from Rocky Mountain. it has three prongs on the back of the bulb, one for the headlight main, hi, and lo beams. I just need to know which one is which. I'm using the Tusk wiring kit.
More commonly, headlamps are connected from a dimmer switch (basically a single pole/double throw or single pole changeover switch) that feeds power from the source to either the high beam or low beam poles, with the common contact connected to a fixed ground, but either method will function.
thank you locomike. That worked great! I have looked all over for that and couldn't find it anywhere.
