06 TTR 230 oil leak?
My 06 ttr is leaking oil right at the front where the motor meets the case. Do I just need to tighten down the motor or does the gasket go on these? Any advice is appreciated.
well I torqued down the 4 bolts on top of the motor to 40 ft lbs as per torque specs. Looks like it's still leaking oil. How hard is it to remove the jug to replace the base gasket? Do I need to pull the head off the top or can it come off all in one piece?
