Keihin PD Jets, Needle and Slide?
hello, have a Keihin PD from ebay (for GL 100 apparently).
EDIT: figured out which main jet it uses :thumbsup:
http://jetsrus.com/a_jets_by_carburetor_type/jets_keihin_99101-393_main_round_28-xxx.htm
pilot(slow) jet
http://jetsrus.com/a_jets_by_carburetor_type/jets_keihin_N424-21_slow_26-xxx.htm
would this be the correct needle?
http://jetsrus.com/a_jets_by_carburetor_type/needle_keihin_N427-45_PE_20-24mm_1024-36_H-9900.html
would it be safe to assume this carb is the same a PE20/22/24?
[/url]
Carb Markings say:
Slide neck
KEI HIN
K T
Above float bowl
PD
022[A]RAK2
Serial #? laser printed on top of intake
GZZH261A3EA1021
Bottom of slide
74B
Needle
P264A
Edited by sil
