Mt43
I just ordered an MT43 for out back on my DRZ. I'm running a tube now with no issues on a Dunlop 739. I ride desert hard pack and rocks. I've considered a Tubliss, but have heard mixed results. I do not run a rim lock now. If you have this tire, please advise what set up ie; tube/rim lock/tubliss you are running and how you like it. Thanks. See you out there.
The Tubliss has a built in Rimlock as well as the entire rim acting as a rimlock with it in place I have that set up on my KTM right now and love it at low pressures like say 8-10psi. I would not ride on the street like that but for the single track It is perfect.
I have that on my KTM 450 with tube running 8.5 psi, many other friend same setup no problems.
Thanks. So you are running the Mt43 with no rimlock on a standard tube and it works fine?
yes, I do have the heavier tube though, and two of my other buddies too.
