CRf 150f f FIRING PROBLEM
What would cause a CRf 150 f not to fire I grabbed the kill switch wires and it shocked me but if I grab the spark plug wire it won't ack me I tested it and it is not getting no fire what coils be wrong does it need a new one
Well you can try cleaning your spark plug. An easy way to locate the problem is to check for spark at the plug, thin trace the wire back until you have spark. I'm assuming it doesn't have a battery, but if it does just make sure it has a good charge
