2010 Husaberg FE390. Oil leaking from base of shift lever
After riding I have been noticing that the engine casing is showing signs of leaking oil. I traced it to the base of the shift lever. I removed the shift lever and repacked the bearing behind it with grease. After a few rides the problem is back. A buddy of mine mentioned something about having to possibly split the cases. :thumbsup: Anyone have any idea what is going on or encountered this issue previously?
I am Ok with a wrench, but not that great at diagnosing issues.
Replaced shaft ring seal. Fixed.
