Headlight wiring, help!!???
I posted this on the kawi klx forum, but since that forum is kind of small, I figured I would post it here too.
I am trying to install a headlight on my wife's klx140. I already got the wiring on the bike figured out, and the wiring on the switch also. BUT... I bought a chinese headlight that did not come with instructions! I am having a hard time figuring out which wire is positive, which one is ground, and which one is for the high/low beam. Here are some pics:
As you can see, the headlight comes with a separate bulb for the high beam and I'm pretty confused. Any help would be GREATLY APPRECIATED! Thanks in advance!
Edit: I forgot to mention that although in the first pic there are two green wires, at the end of the cable (where you join the wires with the ones on the bike) there is only one. So there are only 4 wires. White, blue, green, and brown. Thanks!
The smaller bulb in the corner is a Euro running light, brown=ground and green=hot. Pull the cover of the center socket and just see where the wires go. Since there are three leads you can conclude one is high beam, one is low beam, and one is the ground. The headlights I have worked with green is usually the low beam and hot for the the running light. I hope this helps.
I'm guessing green = ground (technically "common"), since that's a more generally accepted color and that same color goes to both bulbs.
The brown wire on the little bulb is likely always-on.
Which leaves two other wires, blue and white. Try 'em and see what's what.
I'm gonna mess around some more with the wires today and see what happens. Anyone else worked with headlights before that wants to give their opinion? I would really appreciate it.
  • Similar Content
    • By Big64N
      Good condition with a long list of high end upgrade parts.
      Rekluse EXP 3.0 with cover and slave
      EVO- Ellensburg suspension tuning for 6' 200# expert rider
      Fork bleeders
      Trail-tech map switch
      Moose 1-1/8 flex bar
      CYCRA probend bar guards
      SXS skid plate with linkage plate
      Clutch and water pump guards
      Frame guards
      Fastway Evolution III pegs
      SRT Pro Armor radiator and rear rotor guards
      Acerbic Front rotor guard
      TM designs chain guides
      DID race chain
      Renthal sprockets
      Gripper seat
      FMF F-bomb header
      Dirt Tricks timing chain tensioner
      Pro Wheel, wheels
      Tubliss front and rear
      New top end and valve adjustment 60 hours old
      Many more aftermarket parts as well as spare parts and service manuals included in the sale.  Willing to include 4 sets of tires with 80% tread left for full price.
      Great bike with plenty of life left and set up for anything from single track woods to wide open dessert.
      Can hang with any of the 450's but is much easier to handle in the tight woods.
      Priced to sell at $6000.00
      Willing to consider reasonable offers but no trades or carry.
    • By filterx
      34 Days and what ever in Beautiful Chile
      http://www.fim-isde.com/home/
    • By Project57
      So if I can’t buy a used bike from out state looking for anyone that has or knows of a low mileage California 2017 / 2018 Beta 500 RRS?
      Thanks in advance!
    • By Project57
      Looking to buy a used Beta 2017 500 RRS from outside California.  Can I plate (Register with CA DMV) the bike in CA?  If so what is the best way?  Don't have the money to put down for a new bike from a Dealer in CA.  Any help or sugguestions would be appreciated.  Thanks in advance.
    • By MANIAC998
      This continues to be my favorite trail/race weapon!! In our Eastern tight woods, power is not King, handling is. And this thing outhandles them all!!!!
