99yz 250 ims 3.0 install question
I picked up a 3.0 gallon ims tank used for my desert bike, a 1999 yz 250 and i'm trying to figure out how it installs....
The tank is bare, in the front there is two screw holes with nothing attached, in the instructions it mentions somehow bolting it up to the radiator.
Is there supposed to be a bracket attached at the front? If that is the case does it just attach with a bolt through this bracket I don't have then threw the radiator mount ?
I think you use the bracket from your stock tank. Note that it probably uses only 1 bracket instead of the stock two.
Thanks, that should do the trick then, I have one other question though, the tank seems pretty close to the cylinder. Is this normal?
