Newbie here--contemplating a 250x
Should I be afraid to buy one of these bikes? I have always been a Honda man but reading on this forum scares me a bit. I have a chance to buy a clean 2005 250X that still has 50% original rear tire use left( I'm guessing under 30 hrs. on bike ) for 1700.00 . I believe this is a good deal but if I have to be replacing valves/crank/etc. all the time than I'm thinking maybe this bike is not a good choice.This bike will be trail ridin only and not abused or over revved.
I think that's a good deal, I havn't had any problems with mine yet, but as you see some have issues with the top ends wearing out. I ride trails and usually a slow rider.
You don't need to do it all the time its just part of a modern 4 stroke I have an 05 crf250x and all it has is s crf250r cam/exhaust and kibble white valves and mines has a lot of hours
Sounds like a great price to me even if you had to do some work to it. I was like many folks here, basically not having any trouble with my 04. I read and read and read on here wondering if I would see the same problems. And lo and behold.... suddenly it was getting hard to start when cold and was blowing blue until warm...valve seals and gaps closing. Topend rebuild at he shop is $1000 or less. Mine is going to cost around $850 I believe. If the bike hasnt had a rebuild, I'd work the price assuming you need one. But I think at $1700, you are already there, unless this thing is a beater.
i ve got over 2000 miles on my bike with all the original top end parts,if you clean your air filter after every ride and change your oil every 15 hours and stay off the rev limiter your top end should last awhile,that being said i think for 1700 your getting a great deal,like the other guys have posted at that price put some money away for a top end,do some searches and see what your options are,but buy the bike its the best trail bike ive ever owned, i love my X and wouldnt trade it for anything,well accept maybe a ktm300exc lol
$1700 for a 30 hour bike is a great deal (if it really has 30 hrs on it). The only part of the CRF's that wear faster than ANY OTHER racing four stroke are the valves. Cranks and pistons are consumable items on any bike. Valve replacements on the CRFs are maybe a little more frequent than on other bikes, but stay off the rev limiter and clean the air filter, they will last a long time. Once they do go out, replace with SS valves and they will last hundreds of hours as long as you take care of them.
I love my X.
  • Similar Content
    • By Connor Wright
      Hey I have a crf250x 2005 I was riding today in top gear flat out and when I slowed down blue smoke just poured out the exsaughst then I happened to open the air box lid and saw it has what looked like engine oil in it then took out air filter and noticed that there was splatters of engine oil on the inside and that and the channel that goes to the carby had engine oil all over it.
      Also bike got a top end rebuild 15 hours ago
      The engine still runs good and sounds normal
      why would this be happening on a resonabley fresh engine
    • By mikemcbride
      Hey everybody. Quick question for y'all. I recently went riding and about halfway through my ride my motor seized on my '07 CRF250X. I haven't investigated it much but I checked the oil when I got home and there basically was none so I'm assuming that was the culprit. There weren't any metal shavings in the filter or on the plug either. At this point I'm trying to decide to rebuild the motor or just sell the bike as is and let the next buyer deal with it (they would know the deal obviously.) I feel that I'm pretty mechanically inclined but rebuilding a CRF engine is a bit out of my league and I assume paying a shop to do it would put me out more money than the bike is worth. So, I have this question to ask; what would be a fair price for a pretty dang nice shape 07 CRF250X, with a seized motor with an unknown extent of internal damage?
    • By ThomasM.
      selling Hot Cams Valve Shim Kit that i bought for my 2005 crf250x, will also fit crf250r.
      used 1x 1.30 and 2x 1.55 shims. the rest is still there.
      $60usd shipped in the usa or canada
      please contact me for pictures or if you are not sure if it will fit your bike
    • By TerryA
      I have two rides in on my new Rekluse auto clutch and I have to say I'm very pleased. The install wasn't hard, but was pretty much a all afternoon sort of project. I also installed a left hand rear brake kit and a two finger cluth over-ride with the adjuster on the perch (which I rarely seem to need). It has all worked great right from the beginning. After struggling to get up a tricky hill in first gear, I tried it in second and the autoclutch helped me clean the hill easily. Not having to worry about clutch action in techinical sessions has also eased fatigue and just made it more fun all the way around. I ride mountain bikes alot, and having both brakes up on the bars has also been nice as it makes for a set-up just like the bicycle - in fact I like that as much as not having to worry about clutch manipulation. The brake on the bar is especially nice on tricky downhill sections where you need to paddle, such as nasty rock/rut stuff. So first impressions are that it was worth the investment -making the ride more enjoyable and easier at the same time!
    • By Mikey560
      I was driving the bike for 15min or so and all of the sudden the bike stalled. I tried starting it again with no luck. I took the spark plug out to see if there is spark so i ground the spark plug to the frame and there is no spark. I even put a new spark plug in the bike and still nothing. Any ideas what i should check??
