tip of the day
Make sure u check your new Keihn carb out before install.after i installed the 35 pilot and 95 main i but the carb on only to find it flooding big time.Well after 2 hrs messing with the float i finally found the damn problem.
The holder for the main jet was not seated onto the small brass fitting that sits into the slide area.The lock nut on the holder was tight but not adjusted right,u could here that brass fitting rattling around when i shook the carb.
Just because its new doesn't mean its right!!
