Jetting advice: rebuilt xr600
Hi, sorry for the topic, I know everyone hates giving jetting settings cold. Anyways, I'm halfway thru my XR600s engine rebuild, and completely forgot about jetting. I have a hotcams stage 1, intake porting and am putting in an Arias 10.5:1 compression piston, and had the head rebuilt (valves cut or replaces, seats cut) on stock bore. Previously I had a 172 main in there and it was just about right on. I know I'll have to go up, and I will buy a spread of jets. However, do you all have an idea where I should start from and go to?
Thank you!
Elevation? What mods did you have before the rebuild? What pilot jet?
If you didn't have all of those hop-ups before the rebuild, then I'm surprised it wanted a 172 main. That would be too much for my bike even at sea level.
Depending on what pilot you have, I would leave the jetting alone and see how the plug starts coloring. A way to monitor oil temp is a good idea too.
Sorry, it had the hotcam stage 1, full exhaust and intake porting before the rebuild. Plug color was perfect and it felt great with no hesitation from 1/2 throttle on. I'm at sealevel. I'm just wondering the range.
Then the only thing being added to that combination is the piston, right? If that's the case, then the jetting probably won't need to be changed unless pinging on 91 is a problem. The higher compression ratio can also pull a stronger signal on the jets and slightly richen the mixture that way.
  • Similar Content
    • By XR-CJ
      I have this issue several times and cannot seem to figure it out. The four clutch spring bolts are the weakest bolts I have ever come across. I am not sure what the torque specs are, have the shop manual, have searched online and I can only guess it's around 4 ft/lbs. I have been told 8 and they seem to break every time around 7.
      What is the proper torque for these bolts?
      Should I find stronger bolts? I would still stick to the proper torque, but feel as if these things are butter.
    • By XR-CJ
      Prior to reassembling the case, I tested the shifting and it seems the center fork attached to the shaft seems to stick at the steepest section of the drum. I have cleaned and tested all forks and surfaces for smooth movement, tried it with silicone and oil. With very little help, it seems to shift ok, but without the help, it binds.
      Can I assume that once it is together the oil lines are attached and oil is added to the case, the binding will stop? I have tested every scenario short of assembling the entire motor.
      Should I be able to successfully test the shifting with the case apart?
    • By Charles Mrizek
      contact me if you're interested.
    • By Charles Mrizek
      This replaces the tube that connects the two carbs on a 1987 Honda XR600R (it may fit other years).
      Made in the USA.
      Constructed of TPU  (solvent safe plastic.)
       Its durable stiff abrasion resistant yet flexible enough you never have to worry about breaking it when you're taking apart your carbs.
      Fits the o-ring perfectly and slips into the carb nice and tight.
      Matches the rear shock coil.
      If you would like to buy one contact me via e-mail. They cost $20 Shipping is free (anywhere in the USA). $10 off for active duty or retired military.
      Make your subject: XR600r
