Grounded out!
So I have isolated it to the trailer. Pulled all the marker lights and brake lights off. no change....junction box is clean....any other ideas other than pulling off the interior paneling?
cut the wire going to the upper markers to isolate them, if short is gone run a new feed wire, don't tear the walls open.
attempted smoke test.....not completely to smoke just to hot wire. Isolated to right side of trailer. Left side not hot... all feeds off main brown cool.....wire warm all the way to back.
well if you isolated to the r/s you should be able to pin point it, or just replace that wire that feeds the r/s, i suspect its the black wire, since you said the brown is ok.
