No space or money for a full trailer and my car only takes a Class I hitch, so...
I bought a hitch hauler.
These pics are from when I first bought the bike and drove the 2 hour trip to get it home.
:thumbsup:
That brings back memories.
When I was in college, I welded two bars directly onto the back of my Vega angled down at about 45 degrees with a piece of pipe welded between the two at the outer most end. I dragged my bike all over with that thing.
I would suggest taking the chain off when dragging.
+2 on taking the chain off. The chain will turn the countershaft sprocket and with out the motor running there may not be oil getting pmped up to the rotating parts in the transmission. I don't know enough about the oil circuit on the DRZ to say with certainty but I like to err on the side of caution.
Yeah, I didn't wanna try taking the chain off right as I was buying the bike but I plan to the next time I take a long trip with it.
Boy did I get a ton up looks from people on the freeway home. :thumbsup:
That's straight professional right there.
I have access to a welder and only had a Class I hitch as well, so I beefed the hitch up hardcore and whipped up a rack...
I thought I was bad pulling a CBR600f3 on one side of the boat trailer and a SeaDoo GSX Limited on the other from Tampa to Deal's Gap, NC more than a few times...behind a 1.6 liter '93 Miata...and I was still the 'faster traffic' even in the mountains. Hmm.. :thumbsup:
The tongue weight limit of a Class I hitch is 200 lbs but a DRZ weighs 300 lbs.
Dunno what you did to beef it up but an additional 100lbs over the limit seems a bit scary.
yup, but the gross trailer weight is 2000 - so I did this:
Love the looks I got while pulling my bike. This was a class 1 I think. It was bolted to the frame.
Now I have a 90 Celica and the only hitch I can find for it is a class 1 that bolts to the bumper supports. This will be installed vary soon. Pulling my bike behind my Jeep sucks due to the 12mpg it gets.
:thumbsup:
Where did you get this?
what motor did you have in the honda?
It was a bit scary, until more than twice the weight of the original hitch assembly of steel was welded onto it for extra support. Two braces to the trunk floor of 1/4" steel, one extension to each bumper mount, and one cross-brace to the sill of the trunk lip. I would confidently put 500lbs on it. I modeled it in Pro Engineer and did some analysis work, and gusseted the weak spot I found. Was is worth the work I put into it? Well. That... that is another question. The answer to that question is no. :thumbsup:
I used to pull a trailer with two bikes on it with my 1985 civic si when my brother and I did hare scrambles together. It worked great.
My wife could drive, and I could ride out back.
And you could use that cup holder from the other thread for your beer. :thumbsup:
I found a Kendon single rail stand up trailer on Craigslist. 80 mph no sweat, mountain roads to Big Bear Lake Calif. nobody passing me.
Tow vehicle 08 Honda Civic SI 4door 1000 #Lb. towing capacity.
Sits in the garage in a space smaller then a ping pong table. Awesome
Other brands available.
All those rear bumper platforms are problematic the least of all being your headlights now are in all on coming traffics eyes. In the old days we had air shocks to bring the rear up.
You become easy mark for a cop even if you are going 55 mph which you are not, I mean who does. Swerve that car in a accident mode and the whole shooting match could go over. Most vehicles would fail any tip over test with such a weight problem. Case in point the Honda Element only seats 4 as a 3 body in the back seat in sitting position made it fail in roll over testing. Hard to imagine since all the bad press for the Ford Explorer/ Never mind the epic crash the started its slide had 7 persons in it 2 in the cargo area and a under-inflated Firestone tire.
Do not mean to rain on your parade it is insurance agent syndrome and one of my best pals is a R and D Honda Guy.
Kendon™ Stand-Up Single Rail Trailer
$2,147.99 - J&P Cycles
Kendon Stand-Up Single Rail Trailer
$2,199.95 - Rack N Road
Kendon Single Stand-up Motorcycle Trailer
$2,150.00 - eBay
Mustang: $5,000
DR-Z400: $2,900
Tow Hitch: $199
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
