I hate my PJ carb right now!
Here's the deal: freshly rebuilt 1993 CR125. I completely rebuilt the motor with EVERYTHING, all OEM stuff. I mean new crank, piston, ring, gaskets, seals, bearings, everything! Bike rips...when it's running right! I'm having running problems that I think are jetting related. Here's a little history (I ride in MA at sea level BTW):
November last year: 30 degrees, dry, set all jetting to stock (58 pilot, 1469 needle middle clip, 172 main, 1.5 air screw). Ran very nice. Also have the float height set to spec: 16mm.
Last week: 65 degrees, showers, stock jetting wasn't working. Ended up with 55 pilot, 1468 needle (1 richer than stock) at the 4th position, 170 main, 2 turns air screw). Ran very nice like back in November.
Today: 60 degrees, moderate humidity, same jetting as last week. Took 20 minutes to get it to start. Hesitant to rev. Tried getting it to idle because I need to see if my intake boot is leaking (cracking; just not sure if the cracks are all the way through. I'm ordering a new 1 ASAP). It died and took a while to get going again. Definitely wouldn't rev, maybe 4000 RPM max! I shut it down and there was spooge all over my swingarm and rear caliper! So it must be running pig rich!
I'm going to try messing with the jetting again tomorrow if I feel up to it. I ripped my right foot open on the peg from kickin it so much (stupid for wearing sneakers, but I tore my boots open last weekend).
Sorry for my life story, I'm just frustrated with this thing! Is this bike (Pro Circuit pipe/silencer and V-Force 2 reeds) that sensitive with jetting or is it just that the PJ sucks that bad? Today's conditions weren't very different from last weeks so I figured it'd run the same...
If anyone has any advice, please let me know. Also, anyone with a similar year CR125, please let me know your carb settings (including location, elevation, climate, etc of course). I'd really appreciate it!
OK, after a bit more diagnostic work, I fopund I was not getting spark. The same problem I had a week earlier! I disconnected and reconnected all wire connections and got spark.
Re-jetted the bike back to what I had a week earlier when it was running well. Sure enough, thing runs fine. The spooge must've been all that unburnt fuel/oil accumulating from a weak spark. Almost no spooge this weekend after riding for 2 hours!
Completely destroyed my buddy's 2001 KX125! Of course I have more $ into my rebuilt motor than he has in his entire bike. He's trying to figure out the bugs with that thing.
  • Similar Content
    • By SNORE125
      Anyone else have 130 main and 38 pilot jets already in the carb I took the wifes ttr 230 carb apart to add the bigger jets and this bike from 05 that I bought new already had them in it? I was reading that they came with a 125 main and a 36 pilot.
    • By Charles Joseph Miron
      Hello all.  Need a helping hand here..
      I bought an older TT225 and am not about to spend almost $600 on a new carburetor for it. So I'm hoping someone can help me out with an idea of what (other than original carburetor) style, type and brand I should go with..  I'm also having a bit of trouble finding info on this bike.  It's a 1986 Yamaha TT225.
      Thank you in advanced
      Charles
    • By Br0ck
      Hey guys, I went on vacation all summer and let my bike sit (2002 CR250). When I got back I ripped it apart and cleaned carburetor and put it back together and it started fine and ran alright, but idled really high. I adjusted the idle screw and realized it was a ridiculous amount of turns out. I can't remember exactly how many but id say 6+ turns out. My killswitch was a POS and didn't work anymore so I replaced it with an oem replacement. My last ride I crashed the bike pretty bad and I was off the bike for 2 weeks. I can't get the bike to start ever since I got installed the new killswitch. I think I wired it right I just replaced one wire at a time and it looked pretty straight forward. I verified it by testing spark while holding it in I was getting no spark but with it in running position it would spark.
      Anyway I am just looking for some base settings for the Mikuni TMX to get my bike running again, my carburetor has a 35 Pilot and 380 Main jet which appear to be stock. I am located in Edmonton, AB, Canada which is about 2500ft and usually ride between 10-25 celcius.
      Thanks for any replies.
    • By Goon Rides
      Hey guys... so I have a problem... I took the bike at Cal City, broke it in, and while I was doing so, the bike was bogging in first gear (Yes, first gear). Also it doesn't idle at all. I have to keep blipping it otherwise it'll stall. So I adjusted the screw circled in image 1. Well I was listening to the sound of the of the bike, yet the rpm's weren't increasing, and it was still stalling. So then, I unscrewed the screw in image 2, well I found out that it was fully twisted to the right. So then, I twisted it to the left, still nothing; it was still stalling... where's the idle screw? I am sure that the screw in image 1 is for the air/fuel mixture screw, and the screw in image 2 is the idle screw, just broken? I don't know, any and every help would be appreciated.
    • By Zach7018
      So Ive decided its time to pull apart my favorite machine and freshen it up, and I'm looking to make some improvements in the process. I already have a 3x3 mod and a JD jet kit done and it seemed to have changed the world. The stock bike just plain sucked and now its a lot better. I never expect 450 race bike power here but I know there is a little more and I'm wondering if the juice is worth the squeeze. I already plan to add a header and exhaust, an FCR39 carb and stage 1 hotcams. After some research it really seems like those places are where the gains actually come from, so would it be worth it to throw a 434 big bore kit at this bike or just stick with what I already mentioned and a new stock bore top end??? Also my rides are often solo and pretty isolated,how much of a reliability headache can I expect with these mods?
