SM Jetting problem.
So I installed full Leo Vince exhaust with 3x3 mod and JD Jet Kit.
Bike runs really good and idles fine. But after I ride for a while and pull up to a stop light or something it will idle high for like 10-20 seconds before settling back down.
Any idea what the issue could be??
You got 22.5 pilot jet with extended screw or 25 pilot jet with stock screw...?
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
