426 Stage one hot cam
I have an 02 yzf426 with Stage 1 Hot Cams in it and fmf power bomb header and powercore silencer. I am wondering what size jetting i should use for this set up? I am having problems with my bottom end hit out of the corners it bogs until I get to mid range then its fine. Need help Thanks
Check and set up the AP.
I have a new one of the way. Hopefully that will fix the problem
