carb stuck at half throttle 05 crf 450x
hello first time on a forum, so i have a problem with the lever on the side of the
carb where the throttle cables connect to the wheel, when i twist the throttle
half way the lever catches on the blue plastic piece on the back of the wheel.
the only way to release it is to pull the throttle shaft out and the lever will snap
back. thanks
yes but all i took apart was the top to move the clip on the needle up, i even moved it back and still sticks. do you know what that lever does?
You put the slide and slide linkage back together wrong.
