Ktm 300 jet question?
I have an 01 ktm 300 mxc. with a pwk 38mm carb.
.I am in the process of changing jetting. I am at stock jets right now 45 pilot and 175 main. I have the needle at the lowest postion to lean out the mixture. it still run a bit rich . Should I go to a 172 main and put the needle in the third position?
Also the idle is a bit rich if i changed the pilot to a 42 would that be smaller or larger jet?
what needle do you have..
where is it rich,
42 pilot is a start in the right direction.
what number slide is in it,, ?
Sounds like a leaner needle maybe needed.
The 175 main is more than my CR500 used, seems a bit on the fat side.  I run a 160 in my 36mm at over 4500 feet, I go to a 162 at lower elevations.
