Chain Guides
As you know Kawasaki chain guides are not the best. TM Designworks makes a great replacement but they are super-expensive. I thought you might like to know that now Acerbis is making one that is just as good as the TM at a much lower price. I tried mine out yesterday and it is great.
wht is Acerbis pricing? and do they make the other parts as TM Design does?
what are you runing for sprocket / chain set up too?
They also make chain sliders and a replacement block for the stock guide.
I run stock gearing; TAG sprockets, RK chain.
just bought an acerbics replacement block didnt use it yet but seams like harder plastic than the stock one.
So far, I've had great success with my T.M. unit. Good quality, easy to install, stout piece of kit...
Good looking chain guide.......If something happens to my TM....that looks like a great replacement......
  • Similar Content
    • By Tedstrom
      Alright so I just rebuilt my 2012 kx250f complete rebuild. I put the motor back in the bike get everything hooked up and ready to go it takes a few kicks at first (obviously) but after it starts it sat and idled just fine for a while then it stalled out. Tried to start it again wouldn't start I took the spark plug out of it it looked good I was dark and wet. I cleaned it then put the spark plug back in it it took a few kicks but started right back up again then after a while it stalled out again and now I can't get it to start again!? Any help would be greatly appreciated thank you guys and girls for reading and hopefully for the help!!!
    • By DirtBikeHead
      2015 Kawasaki KX250f - 20 hours
      As close to new as I'd imagine you'd get! I bought the bike brand new, I'm older and have taken extremely good care of this bike. Very little use and is COMPLETELY stock - everything is original.
      Comes with the title, original book and map couplers for the fuel injection.
      $4700 - cash
    • By CodyR
      Just thought maybe everyone could post up there youtube channels an we could all help eachother out by subscribing to one another.
      Heres mine ill sub back asap.
    • By bangmyhead
      Time for a top end on my bike, just wondering if there are any alternative Valve springs i can use. I have PC cams and $400 for just the springs and retainers is alil costly at the moment.
      This has been fun in other sections of TT, so I'll start the thread here and see if we can keep it going.
      Let us know what kind of mods, fixes, changes, etc.., you performed today, or just general fun you had with, your KX250F.
      I'll start with.. I installed a correct for my weight Race Tech shock spring, along with a Pivot Works shock spring thrust bearing. Also cleaned out all the nasty yellow plastic/wax crap that passes for grease in the lower shock bearing, and re-lubed it with Bel Ray waterproof.
