Need help, bike won't start
I am working on a 2002 DRZ 400e for my boss. He has been complaining that every time he hit a bump the thing would stall. The last two times he went out the bike stalled in the exact same spot. We thought it was electrical at first, but then thought it was not getting enough gas. I checked the petcock, and been through the carb. I put everything back together, now I can't get it to start. It will start for a few seconds, but when I let off of the started button it dies. Any ideas?
you checked the micro switch isnt faulty on the side stand switch/clutch switch if it has one ????
There is no switch on the side stand. It does have a switch on the cluth, but it turns over fine with the clutch pulled in.
Does it have spark? If the kickstand switch has been removed be sure the wires are right. Air filter ok? Is it on a hill when it dies? May be a float level problem.....try squirting gas into carb and trying to start it....if it starts for a few seconds it a fuel problem. Are you sure jets aren't plugged? Also take your gas cap off and try starting. All lines hooked up to carb properly? Has it been sitting or have bad gas? Has it ever had a valve adjust?...it's easy to stick them and see if they are right. Bad valve adjustment can cause hard starting.
A mere bump in the road will/should not cause the bike to stall.
If it has a clutch interlock switch, it has or had a kickstand one. Verify it is disabled properly.
Another fault can be wiring as it passes the steering neck.
Not the carb.
It has spark. Apparently the lights need to be on to get spark. It has had a baja designs kit intalled. I can get it to fire, but only as long as I have the starter button depressed. Seems like it looses spark when I let go of the starter button.
If you have a test light confirm that you are getting power on the orange wire of the CDI plug all the time if the key is on. The key needs to be on as the switched power (orange) that the key turns on powers both the lights and the CDI. If you were to add another switch that turns off the lights when unneeded it would be fine.
Edited by slowriding
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
