DR100 cylinder ??
does anyone know off hand how thick the cylinder wall on the DR100 cylinders is ?
is there enough to bore to the 125 piston size ?
thanks
Bruce, I just measured my .50 over 100 cylinder, And came up with 4mm thickness. Assuming you need 1.5mm sleeve thickness at the minimum, I'm going to say no, just based on the safety margin
thanks for that :smirk:
