Shock question
When removing the compression cap on an a shock. The larger the discharge of oil that comes out. Indicates it not being bleed correctly? So no discharge of oil is the goal? Also is the band around the mid valve supposed to spin freely? 07 yz250f forks
Chris
Edited by meyer1son
added another question
Hi Chris, do you mean it foams up and explodes out? if so then its not well bleed yes.
On th episton band they do spin i seem to remember, measure it and see if its smaller than the id of the cart, if so you will have bypassing.
Thanks Mog
