Smokes only when cold/warming up.
Had work done on the motor,http://www.thumpertalk.com/forum/showthread.php?t=925466&highlight=
It seemed to smoke only after washing it, probably a coincidence. Then it would do it once in a while (cold). Now, every time it's cold. It always stops, and the motor runs great.
Learned that there is a o-ring in the valve guide that should get replaced, but its a little involved to get to, and the mech thought it was OK to leave.
Is that what the smoking is from? Or perhaps I have another issue?
Thanks
What did the mechanic do to the motor..??and yeah there's some other type of seal on the valves than just the top ones but they are fairly bulletproof..
Two valves were replaced I think they were the exhaust, valve job, replaced rings and honed cyl. One main bearing, replaced 2nd to fix ratio gap, and third gear, worn.
Specifically what seals and o-rings? not sure, only that the small o-ring in question was left alone.
Hard to say what's causing it..Maybe I should just say live with it or we could be discussing possibles forever..Might be that a guide was also worn and needed doing..I dunno really ..so many maybes with smoking..I take it that it never smoked before he did the work..
No, but it has used oil since before he did the work.
Smoke on cold startup that quickly disappears = leaking valve stem seals. Smoke that gets worse as the engine warms up and continues = worn rings/piston/cylinder wall.
Either one a problem! Don't ask me how I know!
What do you call quickly? Mine may smoke for up to a min.
I have had several XRs that had stem seals leaking, smoke usually clears up in 2 or 3 minutes. Keep an eye on the oil level, if there is no appreciable oil loss, I wouldn't worry about it too much.
Mine used to smoke like a coal burning locomotive when it was cold. What is happening is a small amount of oil is leaking past the valve seal when it sits and has to clear out of the combustion chamber when you fire it up. No real harm except your head is going to get a nasty, greasy carbon build-up on it which will lead to problems with pinging. Been there, done that. Mine never burned enough oil to cause a drop on the stick, but it should would put out a cloud!
My XR500R had the same symptoms and I ran it like that for several years adding oil occasionally, it ran great, no problem really. Eventually the valves got carboned up and it started smoking at all times. Basically once it finally started to truly go bad, it went fast. We just tore the top end apart and it's crusted black burnt oil... valves, chamber, exhaust port, even the intake port (no idea how the oil was getting into the intake ports). Otherwise it has normal wear for 27 years, can't wait to get the cylinder/head done and other parts so we can build it and break it in. :smirk:
I have the exact same problem, it will only smoke when cold and not every time but most times it will. It started doing this when I removed the smog crap and piped the base right to the airbox. I am going to re-install the oil separator back on some day. :smirk:
and piped the base right to the airbox. :smirk:
Can you explain this? I want to check if mine is routed the same way. Could have been mis routed after the work was done on my engine.
I removed the smog pump on the side of the engine and removed the black oil separator. I connected the pipe that was connected to the base and connected it to the air box where the oil separator was connected to previously. I am thinking of re-installing the oil separator back.
  • Similar Content
    • By TheLastByte
      Contemplating picking up a BRP in the near future and looking for some perspective.The current owner claims that the bike has about six hundred hours on it, but there's no way for me to confirm as the odo's not accurate.
      I know brp's have a reputation for running forever on stock top ends, but they must eventually have an expiration date. What should I look for on a high mileage bike like this to make sure I'm not setting myself up for disappointment? Also, What are some non engine/transmission related issues I should look for?
    • By TanSnowman51
      Guys,
      Have been riding my 650L for over a year and a half and have been loving every second! In August I moved back to Reno after finishing up my masters at Arizona State. I have been spending most of my time riding around verdi to stampede and the Dog Valley road area. Always looking for riding buddies.
      Was curious what everyone was doing as far as Daves mods or jet kit for the upper elevations 4,000 to 8,000 feet?
      FMF Q4 exhaust, smog delete done so far!
      Thanks!
    • By Alexandre Askmo
      Hey dear folk!
      I need your help.
      A bit of background info, I’m a complete noob when it comes to holding a wrench and doing anything more than filling up the bike. I have however had an interest for as long as I’ve had a bike to make it mine, and that’s why I’m writing to you now. I just bought a donor bike, a Honda NX650 which a friend of mine is helping me fix up and then modify to my liking (I’m hoping to end up with a gorgeous scrambler in about 9 months).
      We found a hairline scratch in the cylinder and need to bore it. This leads me to my question.
      Should I get a 1st overbore performance piston or keep the compression ratio as is? If so is there anything in particular I will need to modify to tolerate the high compression piston?
      If I do get the performance piston, should I also get a new carburetor, hot cam, and new exhausts? I am planning on new exhausts anyway (2-1 from an XRL) and I’m planning on removing the airbox and getting a K/N pod air filter.
      Again, keep in mind I know nothing, my friend has however fixed up a bunch of XRLs and cars but never really used performance parts. Help me out with the decision please, I would also like to keep the whole build to a reasonable cost (I know this is a very relative number).
      I should also add that I want to keep the DNA of the bike, for example keeping the fuel tank instead of switching to a smaller rounder one as one usually sees in most custom builds. The aim of the whole build is to have an insanely fun bike to ride, both in the city and off-road, as well as giving it a bunch of my personality 😊
      Thanks a lot for any help!
      Best,
      Alex
    • By MrCitizen
      I've been rebuilding/restoring an XR650R for some years now (after toasting the motor in 2013). Sent the motor off to be rebuilt, had a local shop rebuild my forks and shock, and took care of most everything else myself.
      As of a couple months ago I had almost everything assembled and ready to run.
      As a final check before adding fluids to the bike, I decided to stick my boroscope into cylinder and take a look. The results were concerning.
      These boroscope pics looked so gnarly that I pulled the head off the motor to get a more thorough look.
      To say that I'm concerned is an understatement. I have pics of the motor internals pre-rebuild, and can confirm that this is definitely a new piston and replated cylinder. I also have all the old parts from the motor, so it does have a new cam, connecting rod, valves, and basically everything else I expected to have replaced.
      The builder "ran the motor briefly to confirm everything ran alright" and then shipped it back to me. I reached out to him with these pics and he said,
      The piston looks like this because he had it machined from 12:1 to 11:1 compression. The streaks on the cylinder wall are normal for one that isn't broken in yet. Regarding the valve impacts in the piston head: "My concern is that something may have passed through the cylinder. How does it run?" I've never run this motor. I can feel these streaks in the cylinder wall with my fingernail. Did he re-use a piston from some other motor?
      Is this dude jerking my chain or is this motor fine to run?
      He's a fairly well-known builder in the XR community and was recommended to me by guys in the (now-gone) XR650R forum.
    • By Jonas Reppe
      I got my XR600r dirt bike giving me a carb issue that I just can not get worked out. It starts first kick and idles well, throttle cracks off nice and crisp when you whack it, but if you ease into the throttle to just above idle it's a spit and sputter pile of shit! Lol. I can turn the idle speed adjustment up to a fast idle and it starts spitting and studdering just the same. Done a lot of research and it points to the pilot circuit. I put a rebuild kit in it and have taken it apart and cleaned it seriously 12 times now. I'm at the point of looking for a different carb body to try. They're about $100 though. A new keihn carb is $250 on eBay. Any thoughts? That pilot adjust screw doesn't seem to adjust anything until it's fully seated or falling out. It has ran ok in that idle to 1/4 throttle circuit before but it don't now. The last 6 removal/cleanings haven't made any changes, previous ones did improve the throttle snap when you whack it.
      The main needle clip is on the middle groove.
      I checked for air leak with some starting fluid when it was idling and seen no change to the way it ran, indicating no leaks.
      Bike has stock jet sizes, foam filter, stock exhaust. 1,830' elevation here in South Dakota.
      I'm baffled..
