2009 WR300 suspension settings
Does anyone know the stock suspension setting for a 2009 WR300 with the 50mm Marzocchi forks.
I have them written down and will post them as soon as i can get to it. Just got back to the States.
Dave
Forgot about this thread.....
I'm 200# and ended up with 5.6 and .48 for the fork springs.
2009 WR300 stock clicker settings:
Forks
Compression = 12 clicks out from closed
Rebound = 12 clicks out from closed
Shock
High speed = max open
low speed = 15 clicks out from closed
Rebound = 15 clicks out from closed
Sounds like the usual 'right in the middle approach'
I usually end up with full soft compression and about 2/3 out on the rebound for the woods. After having my stuff revalved and resprung I have it close to the same... soft compression and middle ground rebound. The 09' stuff is awesome after a competent tuner can fix it. Very good stuff IMO.
How much does your High speed adjuster move? Does it only move that 1/4" amount?
