can a guy with basic mechanic skills....
check valve clearance, set timing and do it right.
Ive never been inside a 4 stroke engine before but have heard from several people that if you have a good walkthrough you can do it...
Yes. And I'm sure there are procedures in FAQ. There is no timing to set unless you are taking cam timing and that is only if you take the cams out to change shims.
I was in your shoes a couple months ago. Never messed with the valves (or any engine work) before. Followed the FAQ valve clearance procedure and had no problems... other than reading my feeler gauge wrong and thinking my valves were out of spec :thumbsup: It's really easy, just take your time, take pictures, and all you really need is a feeler gauge. You won't need to mess with timing unless something else has already gone terribly wrong internally.
Easy if you have nothing to adjust.
If you have to take the cams out, put a little dot of correction fluid on the cams and pins to show you where to put them back to. use a bungee over the frame to hold the chain.
Turn the engine over by hand 720' before starting.
The hardest bit is using the feelers correctly. A lot fail there. light resistance is the key, not what you can shove in the gap.
Make sure that everythings clean, take your time, and if you're not sure, stop, come and check on here.
You'll be fine. I was pleasantly suprised first time I attempted it, even though I had to remove the cams and change two shims, it all went well, and just as described on here.
Take photoes as you go if you want a reference to look back at.
Most users have been able to follow the simple procedures with no issues.. A few users that have "expertise" in this or that,,,, not so well..Seems the non "Expert" does better at reading and following instructions.
No FAQ write up is a replacement for the Service manual and common sense, nor admitting when you don't know something and stopping to ask. ...
DRZ Valve Clearance Check and Adjustment plus Cam timing
  • Similar Content
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
    • By 4strokeOnly
      My bike was stolen, so I'm liquidating my spare parts.
      I took this off my S and replaced it with an SM unit so my speed would be more accurate with the street wheel setup.  I no longer need this spare.  I greased it regularly and it was in good working order when I removed it.  Included is only what is pictured.  Cable not included.
      Suzuki part number:  54600-29F00
      buyer pays shipping.
