125 shock spring?
does anyone know if a rm85 kx 85 rear shock spring is the same diameter as the drz125? id like to make it stiffer but dont want to spend alot of money
thanks
edit..i found out the bbr spring is 49mm in diameter so if anyone has a rear spring from there rm or kx can you measure the diameter and let me know
Edited by 03drz125
found info
Im pretty sure the rear shock is the same on the L and little wheel. The only thing you will need to do is relocate your chain roller so the resivoir will fit. That will take a little bit of welding.
PS, I have a set of BBR fork springs AND a BBR rear shock spring for your bike that I'll sell you. Shoot me an e-mail if your interested levic at hotmail dot com
