DC conversion list...
For converting to DC/battery, does this list seem correct?
TrailTech Voltage Regulator Rectifier:
http://www.rockymountainatvmc.com/productDetail.do;jsessionid=107807D112B698F86823391CCED51D22?webCatId=20&webTypeId=88&navTitle=Electrical&navType=type&prodFamilyId=27240&stockId=223688&ref=gmc
TrailTech 4AH 12V battery:
http://www.trailtech.net/040-BATT4.0.html
TrailTech Capacitor:
http://www.trailtech.net/040-CAP27.html
DDM tuning 55W HID kit:
http://www.ddmtuning.com/Products/DDM-35W-55W-Single-Motorcycle-HID-Kit
Do I need anything else? How would I convert a lighting coil to a floating ground? It has a hot lead that goes to the lights and a ground lead that bolts to the stator plate.
Going on what bike, some may not be able to produce 55 watts and may need an upgraded stator. If you check directly at trail tech web site you have the instruction on how to do it for specific bike.
It's a 65W lighting coil, kawasaki 84 kx250 engine. So in order to float the ground, basically I just connect the coils ground wire directly to the reg/rec instead of grounding it on the frame..?
^Alright. So at higher RPM's the coil will supply enough power to keep the battery charged, correct?
My hid runs on this
I dont know how long it'll run, but it does not flicker once it's warmed up, most hid ballasts are rated 7-13 volts
this is lighting side only on my bike, my charging side is completely separate
So, minus the capacitor, then my list of items to buy is correct?
