2007 EXC 450 Counter shaft play
Does anyone know how much side to side or left to right play/movement the counter shaft should have if any? When I grab a hold of the counter shaft I can move it in and out. is this normal? Thanks for any input.
Jebs website for KTM TSB on subject. Go to #6
http://members.cox.net/jejb/pictures_main.html
.1mm-.3mm is the figure for older KTM rfs bikes. You can feel the shaft endplay. It was more of a problem with the first bikes 10 years ago requiring a check or engine teardown & proper spacing. Haven't heard of this being a current issue, even with the '05. I can feel the slack even though it's within limits.
Thanks. I think mine has to much end play/side clearance.
