1994 kx60 - wont start
Hi , i am new so please be kind if i sound like a .....
I bought a kx60 for $200 in good shape. got it home tried to start it and tried and tried and tried. Then tried with some starting fluid. kicked over then died out. I replaced the plug ( Has spark) drained tank added fresh fuel, nothing. I did notice fuel pouring out of the carb though..... any ideas what to check next...
Idle circuit in the carb is plugged. If it started with the fluid you are not getting the proper fuel mix from carb. Take the carb apart, clean and reassemble and you will be good to go.
tore the carb apart cleaned - bike started. thx!
