KYB Kit Fork 2010-2011
Does anyone has the stock stacks KYB B- Kit fork for a Suzuki RMZ-450 2010?
After few revalves my friend like the stock kit fork more,
but he has not notice the stock stacks.
any help welcome:worthy:
be impressed if anyone has those stacks for you?just stick some 2010 yzf 405 stacks in?
Most of the kyb kit stuff I see is "normal" kyb stuff...normal valving etc etc etc.
Thanks,
i think i need a call to Technicaltouch.
the current stack its way out for hard tracks.
no float , stiff base and single stage rebound valving.
its a Sandsetting for a very fast pro.
not the best for hard tracks:smirk:
tell him to refit the STD fork , would be much better than the kit one
Remove bling?
blasphemy
Only way you can figured out the stock set up is call to technical touch. They have stamped their suspensions and listed the set up because every kit suspension is made for individual purposes. Pick up the number which is stamped to axel lug or top cap.
