06 klx supension thoughts
Wanting to upgrade the suspension a little bit. I'm 150lbs and the tracks I ride aren't hude 10-20 ft table tops & the woops are about a foot tall. Do you guys think I would be ok with a bbr stiffer spring in back and stiffer fork springs or should I go with a new shock & kx 60 forks? Thanks
works shock and kx60 front end would be a lot better then just stiffer springs
