planning an engine rebuild...
hi guys....like the title says, 'planning' an engine rebuild.
the motor has developed a "noise" that i pick up at idle - like a bearing noise.
not sure big-end or main, so before either fails, i'd like to rebuild the motor.
so i am getting prices together, and not sure what piston kit to go with?
was thinking vertex, the piston and con-rod kit aren't that badly priced over here. but i'm not keen on the 1 ring piston. also, the main bearings, would i be able to source them from a bearing dealer or would i have to go oem?
thanks in advance
(100 views and no comments!!!!!)
Edited by MadMatt46
