2010 CRF250R Torque Specs
I bent the gearshift spindle and I'm having to replace it. Anybody know the torque specs for the following:
Water Pump Impellar (My friend and I realized we didn't actually need to take that off for the case cover to come off :smirk:)
Flange bolts 6x20; 6x25; 6x28 (this should be in the owners manual, so no biggie, prob 12ft-lbs)
The nut holding the clutch basket on
Any others you may think of; that should be it.
Also, anybody know the front and rear spoke wrench size?
:smirk:
Inner clutch hub nut is 51 ftlbs,your 6mm bolts should be 7 ftlbs clutch pressure plate springs are 9 ftlbs.can't remember the spokes off hand.Maybe 6.5-7mm for the spokes.
Awesome, thanks! :smirk:
Anybody know the torque spec for the water impellar?
Water pump impeller nut is 9 ftlbs.
