What year engine will fit a 94 CR250 frame?
Like the title says, can anyone tell me what year engines will fit the 1994 CR250 frame? Thanks
92-01 engines are interchangeable.
Thanks, do you know if the same pipe will fit all the years motors? (ie...94 pipe fit 92-01 motors in the 94 frame?)
Nope, I would use the same pipe to correspond to the engine. I believe the 94 is a one year pipe, 95-95 are interchangeable, and I believe 90-93 are interchangeable.
Would the pipe from an aluminum framed engine fit on a steel frame?
