kawasaki kxf 250 valves
Hey,
I just ordered a full OEM valve kit for my kxf 250, I have heard that i dont need new springs etc but is it good to put them in anyway? Also i have heard that you need new shims after you get the valves reseated, will this kit come with the shims or do i have to buy them seperately?
cheers
Would it be worth cancelling the order and getting rid of the springs to save money or should i use them, and is there any other little parts that i could still use from my current valve set to use on the new one to save money?
cheers
Don't cancel the order you need those springs. You are suppossed to replace valves and springs together. You should replace the valve seals too. Since your using oem everything else should be fine
Ohk thanks heaps mate!
