stock 76 TT500 jetting
trying to get a baseline
main jet
pilot
needle
needle jet
help?
this is for an 76 xt 500--i do have a 76 tt carb, but don't know if it has stock jetting--
mj--210
pj--35
needle--5j10-3
needle jet--Q-2
starter jet--60
air jet--0.8
slide--4.5
float level--22.0mm
will see what's in my carb-----
took my carb apart--76tt
mj--190
pj--35
needle--5j10 on clip 3 from the top (must b the 3 on the xt)
needle jet no #
no starter j or air j that i could find
slide--4.5
good luck
thanks. any & all chime in please.
the 190 sounds pretty light. i need to test a bunch
'76 XT500 here.
I'm running a 230 main, all else is stock.
I tried a 45 pilot, but went back to the original 35.
I have a White Bros. pipe w/ Supertrapp silencer.
Also, the airbox is removed and I'm using a K&N clamp-on air filter.
