Valve clearance
Hey guys check valve clearance on my buddies 03 yz250f exhaust valves measured .011 and intake measure .008 my question is how do I kno what size shims I need?
Theres a ton of threads on this you should search first but whateve...
measure the shims that are in there and since the clearance is tightening use a thinner/smaller shim.
so if exhaust spec should be 17-22 or whatever it is, and you measure .011 you would use a shim .008 smaller - lets say the shim in that bucket was 185, you'd want to use a 177 to get it into the middle of spec and widen the clearence. Same thing for intake.
