08 Colorado bed question
I have an 08 crew cab, and have heck of a time getting 2 or more bikes mounted with the 4 tie down points in the bed. I was thinking of getting the Bed Bully, which attaches to the bed rail...but I was also thinking of building my own. Basically i found an aluminum track, used for wall studs, that has notches already in it for tie down hooks, and was going to weld 4 metal plate on the back for mounting to the front of the bed, behind back window. I would use 4BIG washers on the back, to help strengthen and support. Basically my own version of this, but with a total cost of less then $20.
http://www.motocrossgiant.com/VersiTRAX_Tie_Down_Rail_p/versitrax_tie_down_rail.htm
I believe this is designed for full size trucks, not my mini ride.
Any thoughts or suggestions would be helpful!
Thanks,
