1999 rm 250 noise
I did a jump with my rm the other day and when i laneded the bike started to make a high pitch squeal not sure what the noise is comming from,
Not to be sacastic but can we at least narrow it down to either the engine or maybe the rear suspension??
FWIW It could be that either the rear suspension needs grease or the engine is low on oil. :smirk:
i know its the motor because it makes the noise when its just sitting their running. but i dont know where in the motor it is coming from
check the c-clip on the gear that drives the water pump.
you will have to pull the right hand side cover to get to it.
