TTR 110 Carb question
I took apart the carb on a 2008 ttr 110 to clean the jets.
Referring to the picture below when I removed the main jet (#3) along with #38 but there was no part #4. When I look in there I can only see the bottom of the needle, Is that wrong? Am I missing something here shouldn’t have part #4 fallen out(just like #38 did) when I unscrewed the main jet?
Thanks!!
Edited by topi1967
It's a pretty tight fit. That piece almost always stays in the carb. Look through the bore of the carb in the direction of fuel flow, and you should see the top of the piece poking out of the machined recess.
thanks, that's all I needed.
