YZ250 "headlight"
I just bought a YZ250 and am looking for guidence on putting a headlight on it. I only want a front light becuase it will just be used for late night trail rides and fire roads, no blacktop roads. So far I have only found the electorsport stator 35W. Is that enought juice to power a single light? I have also seen some who use helmet lights(trailtech). If I go with the bike light set up, how is the acerbis light? Any help would be appreciated. :smirk:
No, that stator puts out 35 watts AC at mid throttle and above. Not enough to depend on.
YZ is a MX bike, not a trail/woods machine. You should of bought a WR
You are best off going to a total loss battey rig.
Electrosport is junk - good luck making it work. If you can find one buy E-line stator. Pricey however.
While I do like the WR250F, the YZ250 is a great off-road bike and yours looks great!
There isn't going to be ONE SINGLE headlight out there that will work... nope, not one! So if you want, I'll take your bike off your hands for you so you can buy a WR... I'm generous like that. :smirk:
There are some really good helmet mount rechargeable LED lights out there now, for a lot cheaper than a complete stator\flywheel change over and a headlight..
But the downfall is 'planning' on a ride in the dark ,most of mine were 'un-planed'.
Look up: "Mt.Bike headlights"
i wasnt real happy with my helmet light set up. i bought it at a mountain bike store for 100 bones. it was bright, lit up about 100 feet by 30 feet in a field. but the led white light did not let me see shadows and dips in the trail very well. i also confused puddles with holes due to the light. IMO if your gonna spend 3 to 500 on hlemet lights that REALLYwork, add a few more hundred and get the stator. the small 55 watt light on my old quad was much better then my helmet lgiht FWIW.... maybe i got ripped off on my light though :smirk:
I have the Trail Tech SCMR16 HID helmet light. It is very bright and works great, as it should considering how much it costs... ha! I've ridden with just the helmet light, and also used it with a headlight. Under normal trail riding conditions, I think the helmet light works just fine by itself. You have fewer shadows behind every bump, whoop and rock using it, compared to a headlight. However, in rough conditions, using only the helmet light makes everything look much smoother. Using both lights gives you a little better depth perception and allows you to see all the rough stuff better.
I have a Baja Designs Tecate light off my old KTM that I had rewired to run on batteries I have hid in my airbox. Works well but is pretty expensive for the light. For a headlight I have always ran a Nite Rider Headhunter light, but my wife bought some bicycle lights last year called Magic Shine, they put out alot of light for a pretty cheap price. From what I have seen Cyclops highend stuff is good, but the lower end lights are very weak. Just my 2 cents
  • Similar Content
    • By doolan
      Hi guys I have a 2018 yz250 looking at changing springs front and rear I'm 200 pound ride b class moto.
      Having problems choosing spring weights using the calculators as mx tech say I need .45 fork springs and 5.2 rear but racetech say .48kg forks and 5.8kg rear.
      What are other bigger guys
    • By YamahaYz1
      Hey TT, I know there's endless topics on YZ250/ two stroke tuning in general but I have not been able to find one that helps me get my 09 YZ250 set up for my riding style and where I ride so I'm here asking for help. I got this bike around 1.5 years ago and have not known how to set it up properly. I know no one can give me a perfect set up but I'd like a good starting setup to work from and tweak to perfection. Throughout this time I've had this bike, its always been covering the bottom of the entire silencer and dripping all over the swing arm and rims with oil. Also, the joint between silencer and expansion pipe has oil around it too but I've heard I have to close the gap a little to squeeze the silencer a little tighter and stop the leakage there. I don't have too much experience messing with carbs but I've messed around with previous two strokes and tuned them a little better. I change the oil on my bike after 15-20 hours on it and clean and oil the air filter after almost every ride. The sparkplugs never last me more than a few months but recently have been lasting me no more than a few weeks. With the excess oil from the pipe and spark plug fouling you can see why I need to set my bike up to stop this.
      The bike:
      Completely stock with V-Force 3 Reeds and a FMF Shorty silencer.
      Usually running around 32:1 premix with 91 pump fuel because I prefer to keep it well lubricated instead of running rich.
      Riding:
      I ride enduro in Ontario, Canada. So mostly single track and some fire roads but nothing close to MX and not a lot of time wide open. Therefore, probably mostly 1/4-1/2 or 1/4-3/4 throttle range.
      Where I ride:
      Usually 0-500' above sea level. With temperatures ranging from around 15-35 degrees Celsius (55-95 Fahrenheit).
      If anyone can give me a setup to go from, that would be very much appreciated. Even multiple set ups for different temperature ranges or any suggestions would be much appreciated. Thanks and sorry for the long read, I just didn't want to leave anything out. Ask any questions if you have any, too.
    • By Goon Rides
      Hey guys... so I have a problem... I took the bike at Cal City, broke it in, and while I was doing so, the bike was bogging in first gear (Yes, first gear). Also it doesn't idle at all. I have to keep blipping it otherwise it'll stall. So I adjusted the screw circled in image 1. Well I was listening to the sound of the of the bike, yet the rpm's weren't increasing, and it was still stalling. So then, I unscrewed the screw in image 2, well I found out that it was fully twisted to the right. So then, I twisted it to the left, still nothing; it was still stalling... where's the idle screw? I am sure that the screw in image 1 is for the air/fuel mixture screw, and the screw in image 2 is the idle screw, just broken? I don't know, any and every help would be appreciated.
    • By Nolan Mitchell
      I’ve got this 85 yz 250 with a odd rev problem, it starts and runs fine, good compression but when you Give it wide open throttle in newtral the bike will rev to around 5.5 k rpm like platow for a bit there, once you’ve waited  a few seconds there for it to clear itself out until it reaches its max rev whatever it might be 7k rpm even happeneds when the bike is defenetly warmed up after a wide open pull. But it doesn’t bog at idle to 3k. The trotte response when riding seens normal. However i don’t feel that the motor is getting its full potential. Honestly I’m just confused on what’s goin on and i need some help
